Surface Pro doesn't wake up from Standby
2013-02-13T22:14:56+00:00
When I put my Surface Pro into sleep mode (not hibernate, as I disabled that using powercfg -h off  via command line), pressing the power button, Windows button, or pressing keys on the keyboard will NOT wake it up... the screen stays blank, although I can press the Windows key and feel it vibrate as to acknowledge that I've pressed it.
My only solution is to power off the device and then power on, which is not ideal for obvious reasons.
I have not made any changes to power profiles or the device, and I've spent quite a bit of time installing my software and copying files... I really don't want to reset it if I don't have to. I have already installed all available Windows updates.
Any advice?
2013-03-21T15:28:19+00:00
This from that other thread I referenced appears to have resolved the issue:
  1. Open Device Manager from the Control Panel or however you normally open it
  2. Expand Network Adapters and double click Marvell Avastar 350N
  3. Choose the Power Management tab and make sure the checkbox is checked for Allow the computer to turn off this device to save power
Thanks all!
Leo
2013-02-14T14:17:29+00:00
Have you altered the wireless network card in Device Manager to not allow the computer to put the device to sleep to save power via the Power Management tab on the card? I had inadvertently done this and it caused my Surface Pro to not wake properly.
To clarify for anyone else running into this:
64 additional answers
    2013-11-19T18:08:24+00:00
    I have also had this problem. My Surface Pro (128) will not wake up from sleep mode yet continues to burn up power with the fan spinning madly. The only way out is to do a manual power down with the power button.
    I have checked the power settings on the Network adaptor (Marvell AVASTAR...) and all is as it should be.
    I have also had a couple of blue screen experiences with the message 'driver_power_state_failure'
    Having analised the dump file with BlueScreenView, I see that the ntoskrnl.exe driver has crashed but have no idea what that means.
    Can anyone help me?
  2. Deleted
    2013-12-10T01:31:18+00:00
    What if there is no Power Management tab under the Marvell network adapter?
