Surface Pro 7 Slow WiFi
2019-12-28T15:20:10+00:00
Hello everyone,
I am working with my new Surface Pro 7 i5 one or two days now and unfortunately, I still have severe wifi issues after installing all updates. Speed is between 0 and 1,250 kbit/s.
After searching for this issue, I found several entries describing this kind of problem and some workarounds like setting the MIMO Power Safe Mode to a different value. (as described here) I did all this but still, there is no improvement.
Any other suggestions on this? Is this a known bug? Is there a patch on its way? Is Microsoft working on this?
Any help is greatly appreaciated.
Thanks a lot
Tim
    2020-03-06T16:54:47+00:00
    So far so good with "smps=static"
    I'll update if the problem reappears today, but first thing this morning I still had good bandwidth.
    Thanks very much Ssssh.
    2020-03-06T17:01:25+00:00
    Hope it works, it did for me so fingers crossed :)
    2020-03-06T17:58:50+00:00
    Darn it! Back to 22MB/sec. Ugh..............
    2020-03-07T05:22:58+00:00
    I spent a couple of hours with Microsoft support tonight, reloading everything and it's brother.  End result: usual story, initially 300MB/sec+ and now 20-ish MB/sec.
    2020-03-07T05:39:42+00:00
    The only other thing is the router, what make and model and what settings do you have. Im working in Saudi at the moment and my unifi setup is in uk. From memory mine are.
    smart queues off
    band steering off
    wifi optimization on
    DPI on
    IPS on
    DTG 2
