Surface Studio connt run Corel Draw products
2016-12-29T21:13:30+00:00
I have been trying to load Corel Draw x8 products onto my new surface studio for a couple of weeks. The install and authorization works but on startup a windows popup reports "program has stopped running" before it loads up. All x8 products give the same result.
I have reinstalled several times. I have been working with Corel Techs that have had me load every kind of updates, local and downloaded installs, erasing temp files, verifying updated drivers and so far there is no fix.
The x8 product works fine on my old surface pro tablet (original surface model).
I talked today with another Surface Studio owner having identical problems. I'm hoping that Adobe is not the only graphics options that is compatible with this new device.
Has any other Surface Studio owner been able to load Corel successfully?
Surface | Surface Studio | Install and update
2017-01-27T11:13:34+00:00
There is a fix posted
http://community.coreldraw.com/talk/coreldraw_graphics_suite_x8/f/832/p/54488/261974#pi1484=4
by Corel..
"Hello all,
here is a temporary link to everyone who encounters the problem. In the next few
days, I will replace this with a link to the detailed Knowledge Base article,
but wanted to get this in your hands as quickly as possible that doesn't require
to change the color profiles on the Surface Studio.
This is a new installer of CorelDRAW Graphics Suite X8 that resolves the crash
at launch on the Microsoft Surface Studio. If you have previously installed X8
on the computer, you will need to first uninstall it and download the updated
version. Here are the detailed instructions:
•While online and connected to the internet, uninstall CorelDRAW Graphics Suite
X8 and all components, including Corel Graphics – Windows Shell Extension.
Remember to take note of the email address and password used to sign in with
this installation, along with the serial number, if applicable.
1.In Windows Control Panel, click Uninstall a program.
2.Double-click Corel Graphics – Windows Shell Extension on the Uninstall or
change a program page.
3.Click Yes to uninstall
4.Once complete, double-click CorelDRAW Graphics Suite X8, and click Remove to
uninstall.  It is recommended that user files also be uninstalled. To remove
user files, enable the Remove User Files checkbox under the Remove option.
•Download and run the updated installer of CorelDRAW Graphics Suite X8 from
here.
•At the end of the installation process, when the sign-in dialog appears, please
enter the credentials that were used with the previous installation of the
trial, perpetual version (full or upgrade) or subscription. It is important to
use the same credentials that are already associated with the
purchase/subscription.
Happy CorelDRAWing!
2017-01-27T04:44:30+00:00
OK, Corel has created a new installation file that has solved the conflict. If you are looking to load Corel Software on a Surface Studio device you will need to use the new installer. The link can be found in this thread on the Corel Community forum:
http://community.coreldraw.com/talk/coreldraw\_graphics\_suite\_x8/f/832/p/54488/261974#pi1484=4
23 additional answers
    2016-12-30T22:05:52+00:00
    Looks like it won't run then.  That is a shame.  When I had the issue with the WordPerfect Suite, I had contacted Corel's support team on the issue and looks to me like they gaffed the issue of Windows 10 off.
    If it absolutely cannot run, take a look at the software that Xara has and it is not 'cloud' software and you can keep everything local.  Could save you money in comparison to Adobe's products.  I have their "Photo & Graphic Designer 7" which is a bit old now but it ran pretty good in Windows 10 and on my Pro 3.  It did crash two times, though but most of the time it worked very well.  I didn't see if they had any trial software that you could test, so, it would be a bit of a gamble.
    There have been some complaints with Adobe's Creative Suite in regards to the menus being too small to read.  Other than that, their software did work.
    Good luck with it.  Saving up to get a Studio myself.
    2016-12-30T21:08:25+00:00
    James, no 3rd party antivirus, also I turned off Microsoft Defender while trouble shooting
    2016-12-30T20:57:10+00:00
    There is another thought that just came to mind - are you running a 3rd party anti-virus program?  If you are, get rid of it and only use Windows Defender.  Those can clash with software as well.
    If anything, try shutting off your anti-virus software and/or any other program you may be using and try re-installing CorelDraw again.
