Surface Pro 4 "Plugged in, Not Charging"
2016-03-16T13:08:47+00:00
So I did a search and found a lot of similar issues with the Pro 2, but nothing that really fits what I'm dealing with regarding my pro 4.
I've already swapped it out once before for this same issue, so I don't believe this is just a one off issue.
I have a Surface pro 4, i7, 256gb, 16gb RAM. I use the Surface pro 3 docking station with insert and have connected through the dock the following:a Single Dell 24" monitor off the displayport out of the docking station, Satellite/sub sound system, wireless keyboard, wired mouse, and a bluray drive. So that's the setup.
here is the issue. When ever I attempt to do anything that is somewhat power intensive, I get the  "Plugged in, Not Charging" issue. For instance if I play "Call of Duty: Heroes" which is a download from the app store it stops charging. Doesn't matter if I have the surfaced docked or connected directly to the supplied power cable.
The batter charges, it lasts 4-5 hrs when not on the charger. If I'm just doing word processing or watching a video, if I'm not compiling code, digital circuits, or playing a very very very low demand game it works just fine.
Anyone with a similar issue? Anyone able to get this resolved?
2018-03-15T15:48:24+00:00
Here's what worked for me just now.
I've got a Surface Pro 4 i7/16GB  with the Microsoft Dock, and it stubbornly refused to charge.
I went into Device Manager, ![](https://learn-attachment.microsoft.com/api/attachments/1f924923-6af6-422b-8472-31c1b800abbc?platform=QnA and for each of the "Microsoft AC Adapter" and "Microsoft Surface ACPI-Compliant Control Method Battery" devices, I selected them, right-clicked, "Uninstall Device", then went to Action, Scan for Hardware Changes, and it re-appeared.  After doing that to each of them, my SP4 started charging again.  No reboot necessary.
More info can be found in the Surface battery won’t charge troubleshooting article.
Hope that helps someone out there.
Your mileage may vary.
-KwM-
97 additional answers
    2017-11-06T14:22:25+00:00
    Hi Chris,
    My SP4 is experiencing almost exactly the same issue, having started last week some time! I don't use a docking station and have i5. The battery status is always 95% plugged in, not charging.
    Andy
    2017-11-06T15:38:14+00:00
    Hi Chris,
    Andy
    Hi Andy,
    Thanks for taking the time to reply.  Do you have any thoughts on what you're going to try next?  Rebuild to factory image?  Or (assuming you're out of warranty) go for a swap-out?
    Chris.
    2017-11-06T15:55:49+00:00
    Hi Deke,
    Your problems sound like a royal pain in the ass for sure, but I don't think we have the same problem.  My battery will simply not charge at all, via any mechanism.  No amount of unplugging and re-plugging into either the dock or the mains directly will solve the problem.  As soon as I unplug the mains connector cable the Surface dies immediately.  It won't switch back on at all unless connected to the mains.
    Chris.
    2017-11-06T17:30:55+00:00
    Chris,
    Not yet. I’ll probably attempt a factory reset before a swap out as my warranty has expired. I was kind of hoping it was due to a dodgy update or something and might be corrected in future. I guess that’s wishful thinking...?
    Andy
