Hi everyone,
I'm having a "84% charged, plugged in, not charging" issue as well, and just wanted to explain the symptoms and see if anyone else has the same issue as me, as most of the posts on this threat seem to suggest it sometimes works and sometimes it doesn't, whereas
mine isn't working at all.
I have the Surface Pro 4, i7, 512gb, 16gb RAM pluuged into a Surface (Pro 4) Dock. I have also tried the standard power lead which came with the Surface Pro 4. My Surface Pro 4 will not power on unless it is plugged into the mains. Once booted, if I unplug
the mains cable the Surface Pro 4 dies immediately (doesn't shut down). It seems to be that the battery is completely drained and will never charge up. I think this started happening last week. I've been on the Creators Update for a few months now and it
was working OK. I installed the Fall update this weekend and this is when I noticed the problem, but I have a feeling it was playing up a week or so before this. I just hadn't noticed as I usually have the mains power connected.
I have tried the following:
Microsoft Surface Diagnostic Tool
Microsoft Surface Batter Diagnostic Report
Removing Battery Driver from Device Manager and Installing Latest Driver Manually
Removing Battery Driver from Device Manager and Scanning for New Hardware
Cleaning Connectors and Port
Both Dock and Power Adapter Cleaning and Testing
Hard Re-boot
Mine is out of warranty and I called Microsoft who told me the would swap it out for a refurb for £400 (I'm in the UK). The guy on the phone sudgetsed I at least try rebuiliding it to it's factory state to see if it is a software problem (as I have nothing
to lose as they won't send me mine back to me if I send it back to them).
I'm happy to give this a shot, but will obvsiouly waste a few hours of my life. I have up-to-date System Image Backups, but the guy on the phone actually said if I get send a clean machine, I should just re-install eveything in case there's an inherant problem
in my backup image.
None of this gives me much confidence with the Surface anymore. I really like the device, but have had so many problems with it. It's bricked itself twice causing me to have to do a full restore from backup. Each time I install a big update, stuff stops
working (and lots of people seem to be having the same problems as me). The Fall Update has definately broken Windows Hello, and the Screen Flickers in the top right-hand corner on the login screen.
I'm also a bit reluclant to spend £400 on a swap-out which is only guaranteed for 90 days. It battery issue seems this is a common problem with the Surface. It's just not clear to me if it's a hardware or software problem.
Has anyone out there had the same symptoms as me and performed a factory image reinstall and got it working again?
Many thanks!
Chris.
