Surface Pro 4 "Plugged in, Not Charging"
2016-03-16T13:08:47+00:00
So I did a search and found a lot of similar issues with the Pro 2, but nothing that really fits what I'm dealing with regarding my pro 4.
I've already swapped it out once before for this same issue, so I don't believe this is just a one off issue.
I have a Surface pro 4, i7, 256gb, 16gb RAM. I use the Surface pro 3 docking station with insert and have connected through the dock the following:a Single Dell 24" monitor off the displayport out of the docking station, Satellite/sub sound system, wireless keyboard, wired mouse, and a bluray drive. So that's the setup.
here is the issue. When ever I attempt to do anything that is somewhat power intensive, I get the  "Plugged in, Not Charging" issue. For instance if I play "Call of Duty: Heroes" which is a download from the app store it stops charging. Doesn't matter if I have the surfaced docked or connected directly to the supplied power cable.
The batter charges, it lasts 4-5 hrs when not on the charger. If I'm just doing word processing or watching a video, if I'm not compiling code, digital circuits, or playing a very very very low demand game it works just fine.
Anyone with a similar issue? Anyone able to get this resolved?
2018-03-15T15:48:24+00:00
Here's what worked for me just now.
I've got a Surface Pro 4 i7/16GB  with the Microsoft Dock, and it stubbornly refused to charge.
I went into Device Manager, ![](https://learn-attachment.microsoft.com/api/attachments/1f924923-6af6-422b-8472-31c1b800abbc?platform=QnA and for each of the "Microsoft AC Adapter" and "Microsoft Surface ACPI-Compliant Control Method Battery" devices, I selected them, right-clicked, "Uninstall Device", then went to Action, Scan for Hardware Changes, and it re-appeared.  After doing that to each of them, my SP4 started charging again.  No reboot necessary.
More info can be found in the Surface battery won’t charge troubleshooting article.
Hope that helps someone out there.
Your mileage may vary.
-KwM-
97 additional answers
    2018-02-08T05:02:47+00:00
    I just had this happen to me.  It seems to be a common problem.  I have had my surface Since Black Friday 2016, this is the first issue I have had like this.  Identical to this.
    2018-02-22T01:18:33+00:00
    I bought my Surface Pro 4 at Best Buy and after a year and 3 replaced chargers, my computer will still not charge. I also get a message that will tell me how long until fully charged, but the percent charge left will never change. I cant return the computer or anything because it has been a year even though the thing is a piece of junk, and I dont want to get my computer replaced with a new equally trash computer so I just have to deal with it. This may sound stupid, but when I got really mad, I screamed and punched the screen, and all of a sudden it decided to start working again. probably will continue to not charge tho. Totally stupid and am never buying a surface ever again and will never reccommend it because of the numerous problems I have faced- switching to Apple when I can.
    2018-02-22T02:46:01+00:00
    Sorry to hear your problem goes on and on like that. Mine seems to have resolved itself. So, I'm in the phase of "I like my Surface Pro 4". But it's a quirky machine for sure. I have the 4 gig ram model which I guess regret since 8 gigs would probably make it run smoother. Fewer hiccups. I also wish it had a better battery. Bought it in 2016. I see they still sell them and they're cheaper. I assume with those charger changes you have the plug with the reinforced cord (a little block has been added to prevent the cable from breaking near the plug block.) I think there were fire issues with the earlier plug cord. A great puzzle to me is the facebook app which is so slow as to be useless. But not everyone finds this. So is the intel i5 chip simply not powerful enough to run a facebook app? That's disappointing if true. I'm not sure I would jump to Apple though. I have a desktop Mac and like it, but the Apple world is far from problem free. The machine I like despite the reviewers disputing its usefulness is the Google Pixel Chromebook. Not cheap at $1299 (Canadian). Chromebooks on average have fewer problems and the drawback of not having much storage is not that important. But with the Google Pixel you get a minimum of 128 Gigs so it's something of a hybrid. When and if my Surface dies that's probably where I'm going. For now it's okay. Good luck.
    2018-02-22T04:55:20+00:00
    I have the top of the line i7 and I find it to be a dog, just 20-30% cpu and the fan goes nuts and gets hot. To be honest I blame Windows 10, i use it with 3 additional monitors and it struggles at times doing that and running apps. I had the top of the line SP3 before it running Windows 8 and had no issues with the same setup running the same number of apps. My SP4 ran much smoother with the anniversary update, both creators updates have been annoying to use.
    As for my "plugged in not charging issue" it went away when i replaced the SP3 dock with the one for the SP4. Microsoft sent me a replacement Surface because of that issue plus other issues i had with the creators update, made no difference.
    I like the look of the Surface and the craftsmanship seems top notch but combined with Windows 10 it's the worst PC I've ever used. I'll probably go back to Dell after this.
