Surface Pro 4 "Plugged in, Not Charging"
2016-03-16T13:08:47+00:00
So I did a search and found a lot of similar issues with the Pro 2, but nothing that really fits what I'm dealing with regarding my pro 4.
I've already swapped it out once before for this same issue, so I don't believe this is just a one off issue.
I have a Surface pro 4, i7, 256gb, 16gb RAM. I use the Surface pro 3 docking station with insert and have connected through the dock the following:a Single Dell 24" monitor off the displayport out of the docking station, Satellite/sub sound system, wireless keyboard, wired mouse, and a bluray drive. So that's the setup.
here is the issue. When ever I attempt to do anything that is somewhat power intensive, I get the  "Plugged in, Not Charging" issue. For instance if I play "Call of Duty: Heroes" which is a download from the app store it stops charging. Doesn't matter if I have the surfaced docked or connected directly to the supplied power cable.
The batter charges, it lasts 4-5 hrs when not on the charger. If I'm just doing word processing or watching a video, if I'm not compiling code, digital circuits, or playing a very very very low demand game it works just fine.
Anyone with a similar issue? Anyone able to get this resolved?
2018-03-15T15:48:24+00:00
Here's what worked for me just now.
I've got a Surface Pro 4 i7/16GB  with the Microsoft Dock, and it stubbornly refused to charge.
I went into Device Manager, ![](https://learn-attachment.microsoft.com/api/attachments/1f924923-6af6-422b-8472-31c1b800abbc?platform=QnA and for each of the "Microsoft AC Adapter" and "Microsoft Surface ACPI-Compliant Control Method Battery" devices, I selected them, right-clicked, "Uninstall Device", then went to Action, Scan for Hardware Changes, and it re-appeared.  After doing that to each of them, my SP4 started charging again.  No reboot necessary.
More info can be found in the Surface battery won’t charge troubleshooting article.
Hope that helps someone out there.
Your mileage may vary.
-KwM-
97 additional answers
    2018-01-06T00:46:32+00:00
    Don't know what happened but I now have this problem as well!
    Was it an update?
    2018-01-10T09:24:13+00:00
    We are also experiencing this across many surfaces in our Business, all running 1709 and SP4's
    2018-01-10T13:24:36+00:00
    To be clear, are we all talking about the same issue here?  My issue was that my SP4 always said "Plugged In, Not Charging 74% charged".  If I unplugged the mains cable the SP4 would die instantly.  The surface wouldn't even switch on without being plugged in to the mains.  I restored to a fresh build of the software which didn't fix it.  I personally think this is a battery hardware issue which just goes wrong after 18 months or so on the SP4. I've swapped mine out now for £400 with Microsoft but I'm not at all happy about it. I've totally lost confidence in their hardware.
    2018-01-10T14:34:13+00:00
    I leave my SP4 docked in the SP3 docking station all the time, it fully charges but after 5 hours it stops charging(plugged in, not charging/discharging) and then continues to drain the battery while still docked in the docking station for about two days when it shuts down when battery level gets under 10%.....only when I unplug the adapter from the wall or remove the SP4 from the docking station and plug the AC adapter or place it back in the docking station does the charging start again but after the battery is fully charged, this process starts all over again....it's clearly a software issue of the SP4 that stops accepting a charge after five hours of being fully charged.....
