Surface Pro 4 "Plugged in, Not Charging"
2016-03-16T13:08:47+00:00
So I did a search and found a lot of similar issues with the Pro 2, but nothing that really fits what I'm dealing with regarding my pro 4.
I've already swapped it out once before for this same issue, so I don't believe this is just a one off issue.
I have a Surface pro 4, i7, 256gb, 16gb RAM. I use the Surface pro 3 docking station with insert and have connected through the dock the following:a Single Dell 24" monitor off the displayport out of the docking station, Satellite/sub sound system, wireless keyboard, wired mouse, and a bluray drive. So that's the setup.
here is the issue. When ever I attempt to do anything that is somewhat power intensive, I get the  "Plugged in, Not Charging" issue. For instance if I play "Call of Duty: Heroes" which is a download from the app store it stops charging. Doesn't matter if I have the surfaced docked or connected directly to the supplied power cable.
The batter charges, it lasts 4-5 hrs when not on the charger. If I'm just doing word processing or watching a video, if I'm not compiling code, digital circuits, or playing a very very very low demand game it works just fine.
Anyone with a similar issue? Anyone able to get this resolved?
2018-03-15T15:48:24+00:00
Here's what worked for me just now.
I've got a Surface Pro 4 i7/16GB  with the Microsoft Dock, and it stubbornly refused to charge.
I went into Device Manager, ![](https://learn-attachment.microsoft.com/api/attachments/1f924923-6af6-422b-8472-31c1b800abbc?platform=QnA and for each of the "Microsoft AC Adapter" and "Microsoft Surface ACPI-Compliant Control Method Battery" devices, I selected them, right-clicked, "Uninstall Device", then went to Action, Scan for Hardware Changes, and it re-appeared.  After doing that to each of them, my SP4 started charging again.  No reboot necessary.
More info can be found in the Surface battery won’t charge troubleshooting article.
Hope that helps someone out there.
Your mileage may vary.
-KwM-
97 additional answers
    2017-11-27T06:17:53+00:00
    Same problem.
    At least every few days I will notice that my SP4 is half drained. Unplugging it and plugging it back in usually restarts the charging process, but this is a serious and stupid bug on Microsoft's part.
    This wasn't how it behaved when I first purchased it a year ago, but I can't recall when it first started happening. It seems to be getting increasingly frequent.
    2017-12-08T01:19:04+00:00
    I have been facing this issue for a year.  After I first bought my Surface it happened several times.  The issue fixed itself and after rounds with support they said they would probably have a patch.  As I would have to travel to Hong Kong to return and then wait for a new one I decided to see if Microsoft would fix the issue or at least let us know if they found the root cause.  Suddenly after 10 months the issue returned and it doesnt seem to fix itself.
    Disappointed with Microsoft.  Great product but follow up is terrible.
    2017-12-11T15:12:15+00:00
    Chris,
    All I know is that during the two times I've attempted a factory restore from the mains I've ended up with a blank screen and had to reset. The system then reloads to the previous installed version.
    My instinct suggests this is due to an excess power demand that should be briefly topped up by the battery, but I could be wrong. Maybe this symptom points to something else? Sometimes when using Windows normally with mains only (since the battery stopped charging) the system crashes to the blank screen.
    I'd be interested to know if you've had the same experience.
    Many thanks,
    Andy
    Hello again Andy,
    Sorry for the month long delay in updating this thread.  I had to delay any further investigation into this problem until I was able to setup another development laptop with everything I need on it as I was heavily reliant on my Surface for doing development work.
    Anyway, I tried doing a full recovery this weekend from the recovery partition (which had been automatically updated to the Fall Creators Update image).  I didn't have the same problem with the power cutting out part way through as you had, but something that might be of interest/be related is that when I'm running off my normal surface mains cable, my surface will sometimes just lose power for no reason and completely die (because the battery is fu@#ed).  Usually, when I'm at home I have it connected to the Surface Pro 4 dock which has a much beefier connection cable, so maybe this does a better job of supplying constant power to the surface?  Might be worth picking up a dock if you have good money after bad to throw at your surface!
    But the important information is that a full re-build didn'f fix the battery issue.  After going through the post recovery setup wizard I logged on and had the same problem, so this is definately a hardware problem on my Surface Pro 4.  Given this, I've just decided to reluctantly hand-over £400 to Microsoft for a refurb swap-out.  I'm pretty hacked off, as this is clearly a problem with their manufacturing of the Surface given how many issues that have been reported in these forums.  When the Xbox 360 red-ring of death fiasco happened, Microsoft swapped out of warranty Xbox 360's for free.  they should do this for Surface Pro 4 as well I beleieve.  The only alternative was for me to just keep the thing plugged into the wall all the time, which wasn't really an acceptable option when you've shelled out £2,100 on a "portable" tablet.
    Cheers for now,
    Chris.
    2017-12-14T04:45:34+00:00
    I have this problem too from time to time, but if you unplug and plug back in, it seems to clear up.
