Surface book 2 power button not working unless I detach and reattach
2018-03-28T10:42:16+00:00
This is quite infuriating as my PC won't come out of sleep mode unless I detach the tablet and then reattach it and then hold the power button for 5 seconds.
Am I doing something wrong? I haven't changed any settings
2018-03-29T11:14:35+00:00
If your Surface won’t wake up from sleep, try to simultaneously press the Windows logo key +Ctrl+Shift+B.
Here are some solutions that you can try to help resolve the issue.
Force shutdown your device
Press and hold down the power button until your Surface restarts and you see the Windows logo screen (this takes about 20 seconds), then release the power button.
Install the latest Surface and Windows updates
We recommend that you install the latest updates to keep your Surface performing its best. You can get updates now by checking Settings > Update & Security > Windows Update. You can find the details of the latest update on our Surface Book 2 update history page.
Clean the connectors on your Surface Book
  1. Detach the Clipboard from the keyboard.
  2. Clean the pins on the connector with a pencil eraser. Rub the eraser back and forth across the pins.
  3. Wet a cotton swab in rubbing alcohol. Clean the pins on the long, narrow part of the charger that you plug into your Surface. Rub the cotton swap back and forth across the pins. After you are done cleaning the connector pins, make sure that the pins are dry, and then reattach the Clipboard to the keyboard.
If none of the solutions work, I suggest that you bring your device to a Microsoft Store near you and have it checked by one of our personnel. You may also contact our Microsoft Support team for further assistance. If you're outside the US, contact our Global Customer Service.
Let us know if you need further assistance.
74 additional answers
    2018-04-21T14:32:01+00:00
    Also been having the same issue for a couple weeks. The trouble shooting did not help.
    2018-04-23T02:06:38+00:00
    Hi Kraehe,
    I managed to solve this problem recently. This is what I did:
    1. Download latest Surface Book 2 firmware from here https://support.microsoft.com/en-us/help/4023482
    For some reason there are 2 files to choose from (Can someone inform me why there are 2 files?).
    I selected this SurfaceBook2_Win10_16299_1801009_0.msi as my Surface Book 2 15" current firmware was stated 16299
    1. After install and restart with the new firmware, Surface Book 2 able to turn on as normal by pressing the power button once. However, there is another problem occurred; Detach icon is in RED with X and stated "Harware Failure". Even with this icon, I still able to detach the display using Detach button on the keyboard. Detach and attach the screen few times, reboot....RED icon still appears.
    2. Force restart solved the Detach RED icon issue.
    Perform force restart.
    1.  Hold the Power button for 30 seconds and then,
    2.  continuing to hold down power, press the volume up side of the volume button for 15 seconds.
    1. You will see some unfamiliar Surface Setup Page. Don't change anything.
    2. Select exit and save the setting.
    3. Once Windows 10 restart, Detach icon become normal.
    Hope this solutions solve your problems.
    Microsoft, please fix these problems permanently on your next firmware upgrade!!!
    2018-04-26T20:59:11+00:00
    Oh cool, thank you for posting this : )
    2018-04-28T01:37:46+00:00
    Same issue has been going on for several weeks. It will wake up fine for short periods of time pressing the power button once. But say an hour or overnight press the power button and it does nothing. I have to press the detach button lift the screen press the power button the window comes on and then connect it back to the base and sometimes press the power button again after those steps and it comes on. It works fine otherwise and started having this problem after an update. I tried steps to change all settings to hibernate instead of sleep not matter what etc. still having the same issue.
