Surface book 2 power button not working unless I detach and reattach
2018-03-28T10:42:16+00:00
This is quite infuriating as my PC won't come out of sleep mode unless I detach the tablet and then reattach it and then hold the power button for 5 seconds.
Am I doing something wrong? I haven't changed any settings
2018-03-29T11:14:35+00:00
If your Surface won’t wake up from sleep, try to simultaneously press the Windows logo key +Ctrl+Shift+B.
Here are some solutions that you can try to help resolve the issue.
Force shutdown your device
Press and hold down the power button until your Surface restarts and you see the Windows logo screen (this takes about 20 seconds), then release the power button.
Install the latest Surface and Windows updates
We recommend that you install the latest updates to keep your Surface performing its best. You can get updates now by checking Settings > Update & Security > Windows Update. You can find the details of the latest update on our Surface Book 2 update history page.
Clean the connectors on your Surface Book
  1. Detach the Clipboard from the keyboard.
  2. Clean the pins on the connector with a pencil eraser. Rub the eraser back and forth across the pins.
  3. Wet a cotton swab in rubbing alcohol. Clean the pins on the long, narrow part of the charger that you plug into your Surface. Rub the cotton swap back and forth across the pins. After you are done cleaning the connector pins, make sure that the pins are dry, and then reattach the Clipboard to the keyboard.
If none of the solutions work, I suggest that you bring your device to a Microsoft Store near you and have it checked by one of our personnel. You may also contact our Microsoft Support team for further assistance. If you're outside the US, contact our Global Customer Service.
Let us know if you need further assistance.
74 additional answers
    2018-07-09T05:59:58+00:00
    exac same issue here...
    2018-07-15T06:30:02+00:00
    Same problem here. Firmware did not fix this. I have to press power button atleast 10 times for the computer to start booting up. If I detach it first, it will boot immediately.
    2018-07-15T18:47:16+00:00
    I am having the same issue, which I've been getting around by pressing the detach button as I hit the power button. I've installed the new firmware and did not resolve the issue.
    2018-07-23T04:04:51+00:00
    i have the same problem , the only difference is that i am not a pc expert , so i couldn't fix the problem. can you help me?
    i need a step by step for dummies , if someone can help i will be very grateful.
    Diego
