Surface book 2 power button not working unless I detach and reattach
2018-03-28T10:42:16+00:00
This is quite infuriating as my PC won't come out of sleep mode unless I detach the tablet and then reattach it and then hold the power button for 5 seconds.
Am I doing something wrong? I haven't changed any settings
2018-03-29T11:14:35+00:00
If your Surface won’t wake up from sleep, try to simultaneously press the Windows logo key +Ctrl+Shift+B.
Here are some solutions that you can try to help resolve the issue.
Force shutdown your device
Press and hold down the power button until your Surface restarts and you see the Windows logo screen (this takes about 20 seconds), then release the power button.
Install the latest Surface and Windows updates
We recommend that you install the latest updates to keep your Surface performing its best. You can get updates now by checking Settings > Update & Security > Windows Update. You can find the details of the latest update on our Surface Book 2 update history page.
Clean the connectors on your Surface Book
  1. Detach the Clipboard from the keyboard.
  2. Clean the pins on the connector with a pencil eraser. Rub the eraser back and forth across the pins.
  3. Wet a cotton swab in rubbing alcohol. Clean the pins on the long, narrow part of the charger that you plug into your Surface. Rub the cotton swap back and forth across the pins. After you are done cleaning the connector pins, make sure that the pins are dry, and then reattach the Clipboard to the keyboard.
If none of the solutions work, I suggest that you bring your device to a Microsoft Store near you and have it checked by one of our personnel. You may also contact our Microsoft Support team for further assistance. If you're outside the US, contact our Global Customer Service.
Let us know if you need further assistance.
74 additional answers
    2018-06-20T16:35:39+00:00
    Fixed!
    Go to Device manager and dont see my GeForce 1050 (based on bottom side with keyboard).
    Deattach keyboard and clear contacts with alcohol, after this system will see GeForce and problem solved.
    2018-06-27T21:12:34+00:00
    It seems that yesterdays Windows update solved the issue.
    June 26, 2018—KB4284848 (OS Build 17134.137)
    2018-07-02T06:15:54+00:00
    I have this exact issue. Is there a way to fix this yet?
    2018-07-02T12:11:38+00:00
    Hello Cameron,
    Detaching/reattaching problems as well as power issues can be caused by several reasons like software or driver-related problems. Can you tell us more about the issue? Also, what troubleshooting steps have you done so far?
    For the meantime, we suggest that you ensure that your Surface has the latest updates installed. You can also run the Hardware and Devices troubleshooter by following these steps:
    1. Type “Troubleshooting” in the Search bar and press Enter.
    2. Click on “View All” in the top left corner.
    3. This will display the list of troubleshooters which are built-in in the computer. You can click on Hardware and Devices from the list and you can run the troubleshooter.
    We'll be waiting for your reply.
    Regards.
