2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T01:32:25+00:00
    We appreciate community efforts to address this issue but resetting the device will not change the firmware version which is on your system.
    Josh
    Can someone explain this for a PC noob.  I thought a "reset" was a factory restore.  Wouldn't that also roll back the firmware to its original state out of the box?
    Was thinking of doing a reset now that the update was pulled, but maybe I will not go through it if this is the case.
    2013-12-19T01:48:25+00:00
    I have a question. If people have Surfaces that are unable to accept further charge and installing a new update requires the device to be charging, how do you plan on implementing the fix,i.e., how will people install the next update that is pushed out to fix the issues ?
