2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T01:17:04+00:00
    I can't believe it either!!!  I convinced my GF to get a Surface Pro 2, which she completely migrated over to for the holiday season. We leave tomorrow and I am slammed. When I try to do the command line to stop the update and reboot it doesn't work. Her SP2 is sitting at 10%, NOT CHARGING, per below.
    I tried a rrefresh of the PC and it didn't do anything(except rremove programs from the system)
    When I try then to go and see if I can get any new updates I get this:
    which is a JOKE because the battery won't accept a ccharge
    also llaughable iI the fact tthat I am trying to type this actual post on my surface pro 1 and am getting all these ridiculous extra consonants.
    Gonna try a full PC reset and just reinstall everything hopefully that works.  Thanks for ruining my already packed night MS.
    You make it real hard to be a fan!
    2013-12-19T01:28:15+00:00
    Did a full PC reset and it still shows 10%, NOT CHARGING, and won't let me do any updates because it says it is not charged and not plugged in.  What the !$^%#@^%$!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
