2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T01:11:55+00:00
    Probably not working as this is only for the PRO model.  Not RT.
    Well that piece of information would have been helpful to know if it had been in the original note.
    I was referred after starting a separate thread - somehow my original search failed to flag this thread - and I specified that I was having trouble with my Surface RT, so assumed the above applied to all Surface models.
    Nonetheless, I am still wondering about the firmware update for my RT.
    2013-12-19T01:14:37+00:00
    We appreciate community efforts to address this issue but resetting the device will not change the firmware version which is on your system.
    Josh
