2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T00:50:38+00:00
    I am also having the battery issues with charging and the battery bar resetting to 100% every time it wakes up from sleep mode, or even sometimes when it is powering back up... I have to do a hard reset to get it back to the correct percentage!  This is still happening even with this new update that you just put out. Please fix BEFORE the holidays...
    2013-12-19T00:56:52+00:00
    In a very similar boat. I loved this thing for school but this is just insane!!! some people have to work over the holidays... medical school does not really have brakes sorry MS.  This is your hardware and software and this is just unacceptable!!! I will most likely be selling my SP2 and again be joining the comforts of apple.
