2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T00:09:11+00:00
    To ensure the best experience for our customers during the holiday season, we have taken steps to remove the update for Surface Pro 2 that was previously published through Windows Update on December 10^th^, 2013. We are working to release an alternative update package after the holidays.
    Josh
    Josh - This is embarassing for Microsoft. The faulty firmware update has completely ruined a brand new device (built by MS so you should expect a 1st class support).
    I kept saying how good was the device to everyone I had around and I was really hoping that this was a turning point for MS to gain marketshare in the tablet space but after this episode I will just wait an update to fix it and sell the surface pro2 asap.
    I've mainly bought the surface pro 2 to work during these holidays....but it looks like I will have to wait your patch to have the battery working again....it is just ridiculous.
    I'd suggest to the team that released this update to consider other jobs.
    2013-12-19T00:50:32+00:00
    I completely agree. After coming from a Macbook Air, and showing my friends how useful the Surface Pro 2 was, I now have to eat my words. It's ridiculous that MS can't get its act together, and its latest position that it won't be releasing a fix - or even a rollback - until after the holidays is completely ridiculous. I can't be expected to run an unstable machine with battery problems until then, especially since it's my primary work machine and I use it during meetings throughout the day.
    What makes it worse is that I called tech support and spent an hour on the phone with them. After half an hour, the tech has the gall to tell me that the battery drain was because I was "running too many applications at the same time". After I said that couldn't be the case and that other users were experiencing the same problem, she admitted that was the case and said that she couldn't help me and that my only option was to wait for a firmware update.
    I'm heading out today to pick up a 2013 MBA. Will be selling the SP2 at the nearest possible opportunity.
