2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-18T23:04:35+00:00
    To ensure the best experience for our customers during the holiday season, we have taken steps to remove the update for Surface Pro 2 that was previously published through Windows Update on December 10^th^, 2013. We are working to release an alternative update package after the holidays.
    Josh
    ok but what about everybody who got messed up? can you guys roll this thing back? my surface no longer charges to 100%, it refuses to even try. We need MSFT to at least have a way to put people back to the prior state without blowing away all their OS.
    I'm having the exact same issue. I can no longer charge my Surface Pro 2. I've rebooted it and performed a full shutdown too. The battery system tray icon says "plugged in, not charging" exactly like in the screen shot you provided. This only started occurring the most recent push of updates.
    2013-12-18T23:22:24+00:00
    I could understand this mess up if it were a Dell,Hp or one with god knows what hardware. It just doesn't make sense when its hardware MS spec'd. I would think all our Surfaces were built the same except for storage size. How can a company not control quality when they do the whole thing. My Asus T-100 was twice the machine and under $400.00
