2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-18T19:58:00+00:00
    After getting the failed firmware patch 12/10.
    I stopped the windows update server "net stop wuauserv", renamed the C:\Windows\SoftwareDistribution\DataStore\DataStore.edb" to DataStoreold.edb, restarted the update service "net start wuauserv",
    Then Ran Windows Update Troubleshooter: http://windows.microsoft.com/en-us/windows-8/troubleshoot-problems-installing-updatesThen restarted just to be sure of things, then ran disk cleanup "Clean up system files", and made sure the windows update files were selected for cleanup.After that restarted again for kicks.  And re-ran regular Windows update.  After that it downloaded the firmware patch and installed with zero issues.Perfect Device version matchup in device manager.Hope it helps someone.
    This did not work for me.
    I had to Google "net stop wuauserv" to find out about / remember to use WindowsKey+R to get the Run box, and then entering "cmd" to be able to use the cmd prompt for "net stop wuauserv."
    The link for Windows Update Troubleshooter also did not work. Again, I used Google to get to a link that did work.
    But after completing all the steps and then re-running regular Windows Update - check for updates, I got an error that the Updater could not check for updates! (Sorry, I didn't record the exact message.)
    I ran the Windows Update Troubleshooter again, and that fixed that problem.
    But re-running Check for Updates again returned No new updates are available.
    All this has been tried on my Surface RT, running Windows RT 8.1
    2013-12-18T20:46:29+00:00
    Perhaps they did. I just got a 90 meg hardware/driver update from windows update. Now regardless of power button settings it seems always to hibernate on press. Yet to see if all other problems mitigated at least, time will tell.
    Based on the statement from the moderator I don't think you received a new update, maybe just like I did you received the same December update twice after a system files cleanup was performed. They were clear that the fix will come after the holidays.
