2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-18T18:57:39+00:00
    Perhaps they did. I just got a 90 meg hardware/driver update from windows update. Now regardless of power button settings it seems always to hibernate on press. Yet to see if all other problems mitigated at least, time will tell.
    2013-12-18T19:22:34+00:00
    interesting. I checked and all I see are some irrelevant windows defender definition updates. Maybe the server I connect to doesn't yet have it. I'll keep checking and will post my results.
