2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T00:04:59+00:00
    I ran the WIndows Update troubleshooter and it completed with the following results:
    Problems found
    Problems installing recent updates Not fixed
    Check for missing or corrupt files Detected
    Service registration is missing or corrupt Fixed
    Windows Update error 0x800700571201 3-12-10-T-05_58_1 7P) Fixed
    After running the troubleshooter and returning to Windows Update in the classic Control Panel, the overview says I've never installed any updates but the history still shows the same as before, including the firmware update for 12/10/13 being a failed update.  Running a Windows Update check does not allow me to overwrite the failed firmware update.
    2013-12-11T00:07:49+00:00
    Mine shows as failed too, but I see the Surface Pro UEFI date is 11/11/2013. version 2.4.250.0 - so assume it wasn't updated!
