2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-18T18:20:54+00:00
    This is good but any forecast on a release of a fix to resolve this issue - as very frustrating - and I guess the December update was there to fix something so removal just replaces one problem with another. Thanks.
    2013-12-18T18:48:42+00:00
    To ensure the best experience for our customers during the holiday season, we have taken steps to remove the update for Surface Pro 2 that was previously published through Windows Update on December 10^th^, 2013. We are working to release an alternative update package after the holidays.
    Josh
    ok but what about everybody who got messed up? can you guys roll this thing back? my surface no longer charges to 100%, it refuses to even try. We need MSFT to at least have a way to put people back to the prior state without blowing away all their OS.
