2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-18T18:13:02+00:00
    To ensure the best experience for our customers during the holiday season, we have taken steps to remove the update for Surface Pro 2 that was previously published through Windows Update on December 10^th^, 2013. We are working to release an alternative update package after the holidays.
    Josh
    2013-12-18T18:19:58+00:00
    Josh
    Josh, that's a great first step.  What about those who have already taken the update and are finding huge issues with battery consumption, hardware failures, and issues with booting/sleeping?
    The issues have made our devices almost unusable.
