2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-18T15:32:27+00:00
    I know you guys probably covered this before. But how exactly do I view the html file generated by the batteryreport? I find it under the system32 folder but nothing shows up on the browser. I used both IE and firefox but nothing. I tried opening it on notepad and I can see the script.
    This is mainly because Windows won't let you open a HTML file within 'C:\windows\system32' folder.
    The battery report is generated in whichever folder it is being executed. So if you run CMD (with admin) and change folder to C:\ then 'C:\powercfg /batteryreport' then the report would be generated in 'C:\battery-report.html' Double click on it and the browser will do the rest. Hope this helps.
    Thanks! I got to see the data now on the browser. But I can't see the values for the mWh. Strange. I got percentages  but no number before mWh. I ran cmd under admin, btw.
    2013-12-18T17:40:39+00:00
    Well I broke down and reset my tablet, followed the directions provided before:
    Best bet is to:
    1. Reset your SP2, install the Surface Cover Telemetry Driver via "October2013SurfacePro2.zip".
    2. Change your Windows Update settings to "Check for updates but let me choose whether to download and install them."
    3. And leave it at that until the next updates arrive.
    Seems to be working so far.  Who knows though, it got to the point that every time I shut down, I had to hard shut down, it refused to wake up upon reboot.  Infuriating.
