2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-18T14:40:18+00:00
    I have a SP2 256GB
    I had the same reported failure of the firmware update so a couple of days ago I did an online chat with support and they told me to net stop uwauserv and then delete c:\windows\softwareDistribution\DataStore\datastore.edb then
    run the cleanup
    reboot and run windows update again but it never found the update again.  The took my details and said they would investigate.  How long I have to wait is anyone's guess.  I don't know if it has updated or not - How do I confirm?
    I also reported that the previous day I had the packed my SP2 in a bag in my suitcase with my clothes while I was travelling  When I packed it - it was about 60% charged the following morning it was only 20 % charged and the battery report showed it had turned on and off several times while I was travelling.  They said they had not heard of this and to monitor it.  Reading this thread it appears others also have the same issue.
    Battery Full charge capacity now shows 40,974 instead of the 42,002 has it overheated in the case and damaged the battery - Cycle count shows 4
    Last night I left it on and on the mains - This morning the display was off but it had not hibernated as it was instantly on when I pressed a key. Power settings were - on mains sleep after 60 mins and Hibernate after 180 mins.  The battery report did not show any suspend activity.  So there is definitely something wrong.  I have a 32GB SD card fitted (only plugged it in at the weekend)  will try some experiments to see if that is affecting the hibernation
    Microsoft Support Ticket No 1227426877
    2013-12-18T15:18:57+00:00
    the FB and twitter accounts are handled by marketing. the best shot is to try to get somebody in the surface team to acknowledge this, and they are unlikely due to risk of getting the attention of tech sites.... tech sites are really the ones that can report on this freely.
    unfortunately SP2 users are faced with two choices: wait until January, hope the media picks up on the story and forces and out of band update.
