2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-18T08:50:37+00:00
    Today the System hardware update for Oct 24th came up on Windows update. I decided to install it and rebooted the device. WiFi was gone. Checked Device manager and Marvel Avastar was highlighted. Says driver must be reinstalled. Checked for drivers online but it can't install. Checked for drivers from the October driver pack and it worked. Had to reboot again.
    Weird thing, too. I updated the drivers for the graphics, bluetooth and wifi because they weren't showing the correct version on device manager. Updated online and it says Windows has successfully updated your driver. But when I check it's still the same version.
    I went to twitter yesterday and tweeted a link to this thread just to get MS to acknowledge this problem.
    Today I found myself browsing for tablets from another ecosystem. Yes, I am that disappointed.
    2013-12-18T09:17:32+00:00
    Brand-new unit here. I have disabled all and I mean ALLLLL evil, degenerate and incompetent update!
