2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
  1. Deleted
    2013-12-18T03:12:35+00:00
    MS will not do any "out of cycle" patches unless it is an extreme emergency, such as a massive security hole.
    Not sure how reliable this is, but one user reported his unit was friedby the firmware update and is being replaced by MS.
    Yesterday when I went to pull my SP2 out of my travel case to find it so hot it practically burned my hand. I can't keep it in the travel case now for fear of damaging the hardware.
    I just make sure to Hibernate or shut down.  That's the only way until a fix comes.  I can't believe they f-ed up this badly.
    AND that they have not said anything about it yet.
    Okay here's my report...
    When the SP2 is reset back to its out of the box stock specifications (without Surface Telemetry Driver installed), the wake from sleep/shutdown problem disappears. I've tested this for 2 days & nights. But  as soon as I install updates with exception of the System Firmware Update Dec-10-2013. The waking beast is back. This issue may not lie with the December firmware update alone.
    Further observations... by installing the December-10-2013 Firmware Update, the battery gets hotter, system lasts shorter, but battery meter goes GOD mode. The powercfg /batteryreport shows current battery capacity dropping day by day. I've lost 2000mWh out of 42,002mWh thus far.
    Update: This is twice confirmed.
    Best bet is to:
    1. Reset your SP2, install the Surface Cover Telemetry Driver via "October2013SurfacePro2.zip".
    2. Change your Windows Update settings to "Check for updates but let me choose whether to download and install them."
    3. And leave it at that until the next updates arrive.
