2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-17T20:52:53+00:00
    My Surface Pro 2 is functioning normally now after the firmware/hardware updates (12/10-12/12/13).  Just for comparison, I ran the CPUID HWMonitor (basic, free version).  It erroneously reports my current capacity as "19,321 mWh" whereas "powercfg /batteryreport" gives the current capacity as "41,802 mWh.  In spite of this, CPUID HWMonitor reports my wear level as 0% after 13 battery cycles.
    So take CPUID HWMonitor readouts with a grain of salt.  Looks pretty useful, especially for internal temperatures (important for battery lifetime/aging) but the program apparently is not bug-free.
    2013-12-17T21:15:45+00:00
    in the updates section of the charm bar there is windows update. There you can find an update history.
    For some reason, no update appears there after Dec 2nd.
    The last 5 updates are fore the English dictionary and are listed with an error while installing.
    Anyway to fix this and have a proper update history which is up to date?
