2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
  1. Deleted
    2013-12-17T20:47:00+00:00
    Greetings all,
    Some people may by experiencing a false error message, 80070490. The firmware update should be installing correctly; however, if you received this error message, we recommend that you go to Windows Update and check the Update history to ensure the latest update installed. If it did not install correctly, please let us know on this forum so we can work to fix the issue.
    Thank you for your patience and know we are in the process of addressing this issue.
    wonderful, but two things
    1. are you aware of the problem in page 10 where a lot of people are seeing their battery capacity nosedive after your update? "powercfg /batteryreport". Do something about this or at least acknowledge you know about it and will fix it.
    1. MSFT NEEDS to post the firmware version #s that users should expect to see after the firmware update applies correctly as intended by MSFT. right now, there are a number of workarounds, and some people that claim it installed ok, but NOBODY really knows for sure. Some people did a system cleanup, some did a reset, others...who knows what. It may be possible some people think they have all the updates, but don't, and since the update tends to never come back after failure...who knows...except MSFT what the firmware version #s should be.
