2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-17T17:04:00+00:00
    MS will not do any "out of cycle" patches unless it is an extreme emergency, such as a massive security hole.
    Not sure how reliable this is, but one user reported his unit was friedby the firmware update and is being replaced by MS.
    Yesterday when I went to pull my SP2 out of my travel case to find it so hot it practically burned my hand. I can't keep it in the travel case now for fear of damaging the hardware.
    I just make sure to Hibernate or shut down.  That's the only way until a fix comes.  I can't believe they f-ed up this badly.
    AND that they have not said anything about it yet.
    2013-12-17T19:10:52+00:00
    As for my experience, still a failed update with error code 80070490. Tried the solution where you delete the datastore(dot)edb file and it worked BUT came across the battery drain problem. I finally decided to wipe my SP2 to factory settings and run the update again. I have no typing cover but I do have a microSD card installed. I removed this right before I updated the firmware. Everything went fine BUT battery level is screwed up! When checking CPUID HWmonitor I see the battery's capacity at around 20,000 mWh instead of 42,000 mWh. So I had to do the volume up + power button solution. It somehow resets the battery levels but the problem sometimes reoccurs. I decided to disable the power button putting the device to sleep mode. I just put it to sleep using the charms menu. But it's not 100% effective.
    My fear is that this firmware update could potentially screw up the battery! I checked CPUID HWmonitor and I can't believe the battery's wear level is at 3% even though I've had it for only a month! By the way, the Full Charge Capacity fluctuates from 40,000 to 41,000 mWh.
    Here's a screenshot.
    By the way, I have the Surface Pro 2 128GB model.
    COME ON MICROSOFT!!! FIX THIS ASAP!!! I can't believe I'm getting this much stress over a PREMIUM DEVICE!
