2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-17T15:10:27+00:00
    Just read one user was told MS wants to wait for the next patch Tuesday to fix this problem. Unbelievable! Massively unnaceptable.
    MS will not do any "out of cycle" patches unless it is an extreme emergency, such as a massive security hole.
    I guess that the fact that this issue is getting little to no coverage anywhere is the reason they are doing nothing.  If a major pub picked it up, maybe.
    Anyone know anybody at Giz or Engadget or anywhere?
    2013-12-17T15:47:44+00:00
    Not sure how reliable this is, but one user reported his unit was friedby the firmware update and is being replaced by MS.
    Yesterday when I went to pull my SP2 out of my travel case to find it so hot it practically burned my hand. I can't keep it in the travel case now for fear of damaging the hardware.
