2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-17T14:27:40+00:00
    Just read one user was told MS wants to wait for the next patch Tuesday to fix this problem. Unbelievable! Massively unnaceptable.
    2013-12-17T15:08:34+00:00
    Would love for MS to explain what's going on!
    I can already explain it in a tongue-in-cheek manner.  It's a bug created by MS!
    Come on MS.  You never (really) fixed the issue with Resetting the Pro 2 and having drivers missing, and now you have this issue?
    Explain to me how it's possible for you to roll out updates to "regular" Windows users without an issue but this -- your own HARDWARE -- seems impossible to do right.
