2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-17T13:34:19+00:00
    Greetings all,
    Some people may by experiencing a false error message, 80070490. The firmware update should be installing correctly; however, if you received this error message, we recommend that you go to Windows Update and check the Update history to ensure the latest update installed. If it did not install correctly, please let us know on this forum so we can work to fix the issue.
    Thank you for your patience and know we are in the process of addressing this issue.
     My experience:
    1.  Installed all updates on patch Tuesday
    2.  Firmware failed to install
    3.  Telemetry driver fails to load
    4/. Did a system reset (deleted all user data)
    5.  Reloaded all patch Tuesday updates
    6.  System becomes very unstable waking up on its own.
    7.  Battery % is way off , as is the system time.
    8.  Several system resets and refreshes all yield the same results.
    9.  Overall assessment - Firmware from 12/10 has made system drastically unstable
    10.  Even if I reset and do not install firmware from 12/10, system is still unstable with all the problems reported above.
    11.  Seems you cannot revert back from the firmware even if you try.  I'd at least like to get back to where I was prior to the 12/10 firmware.
    Here is an event log error I get when the machine wakes up all on its own.  Definitely indicative of some kind of firmware issue:
    Log Name:      System
    Source:        ACPI
    Date:          12/17/2013 7:27:49 AM
    Event ID:      13
    Task Category: None
    Level:         Error
    Keywords:      Classic
    User:          N/A
    Computer:      XXXXXXXX
    Description:
    : The embedded controller (EC) did not respond within the specified timeout period. This may indicate that there is an error in the EC hardware or firmware or that the BIOS is accessing the EC incorrectly. You should check with your computer manufacturer for an upgraded BIOS. In some situations, this error may cause the computer to function incorrectly.
    2013-12-17T14:06:59+00:00
    Greetings all,
    I have a new surface pro 2, I'd like to know if it is "safe" to use windows update. Is it advisable to wait until these issues are fixed ? Is it advisable to hide the firmware update and then install the following updates ? Is the previous installation of the new firmware required in order to install other updates? About the "work to fix the issue", I'd like to have at least a vague idea: hours? days? months?
    thank you in advance for your kind answer.
    Removing the microSD card fixed a lot of my sleep, hibination & update issues - hope tHis helps.
    I do not have any microSD, but my unit sometime restart automatically just after i shut it down.
