2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-17T12:46:23+00:00
    Greetings all,
    Some people may by experiencing a false error message, 80070490. The firmware update should be installing correctly; however, if you received this error message, we recommend that you go to Windows Update and check the Update history to ensure the latest update installed. If it did not install correctly, please let us know on this forum so we can work to fix the issue.
    Thank you for your patience and know we are in the process of addressing this issue.
    I have a new surface pro 2, I'd like to know if it is "safe" to use windows update. Is it advisable to wait until these issues are fixed ? Is it advisable to hide the firmware update and then install the following updates ? Is the previous installation of the new firmware required in order to install other updates? About the "work to fix the issue", I'd like to have at least a vague idea: hours? days? months?
    thank you in advance for your kind answer.
    2013-12-17T13:03:01+00:00
    Greetings all,
    Removing the microSD card fixed a lot of my sleep, hibination & update issues - hope tHis helps.
