2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-17T11:44:16+00:00
    Greetings all,
    Some people may by experiencing a false error message, 80070490. The firmware update should be installing correctly; however, if you received this error message, we recommend that you go to Windows Update and check the Update history to ensure the latest update installed. If it did not install correctly, please let us know on this forum so we can work to fix the issue.
    Thank you for your patience and know we are in the process of addressing this issue.
     My experience:
    1.  Installed all updates on patch Tuesday
    2.  Firmware failed to install
    3.  Telemetry driver fails to load
    4/. Did a system reset (deleted all user data)
    5.  Reloaded all patch Tuesday updates
    6.  System becomes very unstable waking up on its own.
    7.  Battery % is way off , as is the system time.
    8.  Several system resets and refreshes all yield the same results.
    9.  Overall assessment - Firmware from 12/10 has made system drastically unstable
    10.  Even if I reset and do not install firmware from 12/10, system is still unstable with all the problems reported above.
    11.  Seems you cannot revert back from the firmware even if you try.  I'd at least like to get back to where I was prior to the 12/10 firmware.
    2013-12-17T12:10:20+00:00
    Greetings all,
     My experience:
    Exactly the same issues here. After 7 resets, the pattern is clear. It seems that the update's failed ROM flash had critically crippled the device.
