2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-17T07:17:22+00:00
    My update failed too... and after reading all of this, I will leave it as failed... i was keen to update to solve the driver crashing issue with Photoshop that everyone has been experiencing.... but this does not seem worth the trouble. Better to wait for another update since it's cumulative anyway....
    Come on Microsoft, get your act together...
    2013-12-17T07:48:10+00:00
    The 12/10 firmware update failed to install for me - see my experience here.
    I followed the instructions in the 2nd post to this thread and finally got the 12/10 firmware to install.
    But I'm still having problems with the unit apparently waking up when the type cover is closed and running at a high CPU utilization - so that when I come back after several hours the unit is very, very hot and the battery severely drained.
    I'm futzing around trying to figure out what to do. I've taken out the SanDisk 64GB MicroSDXC card and restarted the SP2 and it seems to be running okay now. That is, low CPU utilization when not doing anything...vs finding it running for hours at 25% CPU utilization with the type cover closed.
    Would *love* to know what's causing my ongoing problem with the unit waking up by itself after being asleep for an hour or so and running at high CPU utilization. This only occurred after the 12/10 firmware update. It did not do this before. I'm just guessing that the microSDXC card may be involved...not really sure what the problem is.
    Would love for MS to explain what's going on!
