2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-17T07:02:44+00:00
    Greetings all,
    Some people may by experiencing a false error message, 80070490. The firmware update should be installing correctly; however, if you received this error message, we recommend that you go to Windows Update and check the Update history to ensure the latest update installed. If it did not install correctly, please let us know on this forum so we can work to fix the issue.
    Thank you for your patience and know we are in the process of addressing this issue.
    After 6 days...Is this an official response from Microsoft??
    2013-12-17T07:16:30+00:00
    Yes hence I really thought hardware damage. At least the battery certainly is. Even with stock (like out of the box reset), All drivers accounted for. No updates had been applied. The unit still wakes up randomly.
    Before hardware damage I would think maybe some kind of rom flashing went wrong. when I applied the update the unit restarted and even before loading windows it started "doing something" that could have been a rom flashing. I am optimistic and hope this is the case and is fixable.
    Yes exactly, that was what happened the very first time I ran the failed Dec-10-2013 update. The screen paused for a very long time after restart and there were some flashes. Anyhoo, the store where I bought it from 2 months ago said they'd replace my unit! Whooohooooo! First thing I'm gonna do is disable all evil updates.
