2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-17T01:35:41+00:00
    The simple solution DRouj suggested just worked for me on my 256GB SP2.  Make sure you select cleanup system files from the disk cleanup box.  Reboot.  Run Windows Update again.  Found and installed the firmware update.  Reboot.  Firmware update successful.  No need to do all the command prompt work.  Took less than 5 minutes.  Update history still complete.  Thank you DRouj.
    I did that and it seemed to work. After a while some problems appeared, like the battery level stuck at 100%, the time also several hours wrong, and the screen sometimes turns on by itself.
    2013-12-17T02:30:40+00:00
    Since I too have the fail message and 80070490, I tried DRouj's suggestion but did not get prompted for any updates.  Does this mean that my December firmware was installed correctly?  My update history is now blank (presumably until I perform another update (given DRouj's suggestions - cleaning out my DataStore.edb file) but earlier confirmed that the firmware update was a fail before resetting my DataStore.edb file).  My Bios = 2.04.0250 11/08/2013.   Do I have the December update?  It doesn't look like it but why not confirm with you StevenB.
    As mentioned in the  "After 2013/12/10 Firmware / Updates SurfacePro2 battery level gets reset if you put the tablet to sleep and then turn it on again" Q&A, I am unsure of my battery reporting.  I have since set my power button to Hibernate since I was getting all of the symptoms reported like battery %  reset to 100% and not hibernating within the prescribed time limit - resulting in surprising battery drain.  By the sounds of it, others are experiencing the same issue.
    The "sound rocker to + and power button" combination does reestablish my Full Charge Capacity to 40,693 kWh or about, but historically, after a few sleep sessions I re-experience the battery readout problem.  I can no longer wear this risk (of surprising battery drain while under sleep) so as mentioned above I have gone directly to hibernation.
    There is no doubt that the health of my SurfacePro2 has been negatively affected since last week's Patch Tuesday.  I hope you and your team can find a fix and after that, I will reconsider applying Patch Tuesdays as it is better not to mess with a working system as this experience has shaken my confidence.  Please advise.
