2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-16T23:31:27+00:00
    Yes hence I really thought hardware damage. At least the battery certainly is. Even with stock (like out of the box reset), All drivers accounted for. No updates had been applied. The unit still wakes up randomly.
    Before hardware damage I would think maybe some kind of rom flashing went wrong. when I applied the update the unit restarted and even before loading windows it started "doing something" that could have been a rom flashing. I am optimistic and hope this is the case and is fixable.
    2013-12-17T00:49:38+00:00
    The simple solution DRouj suggested just worked for me on my 256GB SP2.  Make sure you select cleanup system files from the disk cleanup box.  Reboot.  Run Windows Update again.  Found and installed the firmware update.  Reboot.  Firmware update successful.  No need to do all the command prompt work.  Took less than 5 minutes.  Update history still complete.  Thank you DRouj.
