2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-16T23:00:09+00:00
    If you know your unit is prone to waking up and running, I wouldn't leave it in a bag until you're sure that issue is fixed.  Leaving it propped up by the kickstand might be the best option if you're not going anywhere with it.
    I always zip mine up in a case after it's cooled to prevent dust and cat hair (!) from getting into the unit but then I have been fortunate not to have wakeup issues except just after the failed 12/10 update at which point I immediately ran the Windows Update troubleshooter.  For me, that seemed to cure the failure to shutdown/wakeup issues that I had in the first hour or two after the update.  Sorry to hear you've not been as fortunate and perhaps Microsoft will make good on your unit if it's suffered real, permanent damage.
    2013-12-16T23:23:24+00:00
    Greetings all,
    Some people may by experiencing a false error message, 80070490. The firmware update should be installing correctly; however, if you received this error message, we recommend that you go to Windows Update and check the Update history to ensure the latest update installed. If it did not install correctly, please let us know on this forum so we can work to fix the issue.
    Thank you for your patience and know we are in the process of addressing this issue.
