2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-16T21:53:17+00:00
    Yes i agree with Johnno74 But i hope they don't just retro fix the December update with out saying or changing the date on it
    I am currently poised to try a fix but...
    I cant spend my life trying all this out everyday until it seems to be working
    MS needs to be open about it and help us get a fix
    2013-12-16T22:20:27+00:00
    Yes hence I really thought hardware damage. At least the battery certainly is. Even with stock (like out of the box reset), All drivers accounted for. No updates had been applied. The unit still wakes up randomly.
