2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-16T21:26:32+00:00
    The problems you've experienced seem to be the exception rather than the rule so perhaps they arise from something other than the 12/10/13 Patch Tuesday updates - or perhaps there are some region-specific differences.  My Surface Pro 2, other than a failed update or two, has worked great overall and has been trouble-free compared to stuff like Wi-Fi issues, pokey performance, and unexpected battery discharge on Connected Standby that I've suffered with the Surface RT.  But overall, I'm very happy with both devices.
    Perhaps Microsoft is a bit distracted with the Xbox One launch, search for new CEO, acquiring Nokia, fusing Windows Phone with Windows RT.  It does seem that sooner or later they try to get it right, e.g. (EDIT: er, make that) SkyDrive sync status indicators coming along.  Unfortunately for the issues raised in this forum, MS seems to have filed them under "later."
    2013-12-16T21:30:29+00:00
    Well, after my initial firmware update failed to install I found this thread and went through the steps for re-setting windows update (stop service, delete DB, clean disk, run troubleshooter) and then I was offered the update again, and the install succeeded, and all driver versions matched what was expected. End of story, I thought.
    Then on 12/12 I was offered the same update again, and install failed.
    Then on 14/12 I was offered it yet again, and the install failed again.
    Then just this morning I was offered it for a 4th time, and this time it has succeeded.
    It looks to me like Microsoft are aware of the problems and working to fix them.  I certainly hope so anyway.... One of the reasons I brought a surface was how many times I've seen over the years how poorly some manufacturers support their laptops/tablets.  I expected microsoft would provide first-class support.
    Ironically the surface pro 2 is currently a fantastic piece of hardware, being let down by some bad software.  Not what you'd expect from a software company but I'm still confident microsoft will get it sorted.
    I just wish microsoft were more open about what is going on behind the scenes here.
