2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-16T10:55:36+00:00
    After my failed update, the diagnostic tool reports the following (any tips appreciated):
    https://www.dropbox.com/s/i9bx3kf7gxqxpgl/Screenshot.png
    I prepared the above as a pdf to send to Microsoft, however there doesn’t seem to be a way to contact support (other than a phone call during work hours, when I too am working, and pdfs don’t work well over the phone). Providing a fax number would be an improvement, haha.
    2013-12-16T20:14:58+00:00
    I've the same report
    Exactly the same
