2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-16T03:50:21+00:00
    Same issue here
    After a fresh Install of win8.1 (reset from métro settings), i've deployed octobre drivers pack with a script using powershell.
    Run Windows Update
    --->Firmware drivers version are ok, numbers match with the december release
    --->Marvell, Realteck, Cover,Wifi and more are still in October driver pack version, and installing manually won't update .
    Also a strange point:
    -After Installing the update , on the first boot, wifi drivers crash, forced to reboot to get the drivers ok.
    I did 24 reset and update on three different sp2.
    Each time same issue
    We need the December driver pack for a manual install
    What about if you just installed the Surface Cover Telemetry driver and left it at that like a SP2 out of the box? No further update of any kind. I did it to mine and it worked perfectly for a while, until the middle of that night, it started back up. Hence my first thought was... unit damage. Let me know how yours go.
    2013-12-16T06:47:53+00:00
    So I reset using the original firmware installed all the updates, used driverstore explorer to remove all the updates back to 09/17 I reran windows update, it found the drivers, rebooted and everything seems to be working ok, I will have to try it for a few days to see how it goes.
