2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-15T17:47:39+00:00
    ok I think I have a solution for those that can successfully get the firmware installed but the drivers for wifi, Bluetooth, display don't update.
    I found a project called driverstore explorer found here. you can actually look at all the installed driver packages and delete them without screwing things up with the driverstore.
    So what I did was deploy the October drivers with systemadmin guys method with dism. installed the updates except the firmware update. once all the windows updates completed I installed the firmware update.
    I then used driverstore explorer and deleted all the new driver packages with the exception of the firmware updates(these were at the correct versions). ran windows update and it found new hardware updates and it installed the latest versions correctly.
    what an awesome tool.
    2013-12-15T22:33:14+00:00
    This is annoying as $@#! Why hasn't Microsoft addressed this yet?  I'm not satisfied with a 580kb hardware update as opposed to the actual update which was over 150mb.
