2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-15T14:30:34+00:00
    I get full battery-drain overnight now (battery only charges to 40,500 now (MS thanks for the damage)
    yes i did the mystical  "Hold vol + and power button for 15 sec...."
    I also get a lot of reboots now when its idle
    "your pc ran into a problem and....." messages are frequent
    Is there a microsoft website where microsoft reads posts and helps people?
    I will do factory reset AGAIN and do the October driver hack (Powershell script thing)
    to get me back to 1 week battery life (lets hope the recent firmware has not blocked this)
    after this i have no where to go and nothing to do
    I really think I should just "jump up and down on it till i get blisters" TBH :¬(
    Ideally MS we need a proper 5gig download image (option) of a WORKING operating system - Pretty please with sugar on top.
    Mac
    I'm interested to know hat is the Powershell script that offers you 1 week of battery life?
    2013-12-15T15:05:08+00:00
    hi Phra Mick Ratanapanyo
    Doing factory wipe then powershell hack for October drivers gave me 1 week of hardly used sleep mode SP2 ( i carried it around in sleep mode whiles on holiday last week in Iceland)
    Link->
    http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfupdate/surface-pro-2-surface-cover-telemetry-driver-blank/c5c4508a-d23f-4bd3-8631-d851d8f776a3?page=7&tm=1387119194106
    I come back do the failed December rollox and then had to do the hack to fix the failed installed and i got full drainage in sleep mode over one night (40,500 down to 0) it didn't even boot.
    I also get no reason BLUE SMILEY SCREENS OF DEATH (BSSOD) even when not touching it
    I have just wasted more time and got it back to factorywipe+powershell and i will see how it goes now
    hope the december didnt do something to stop that working for me
    I am not even sure doing it this way is good for you SP2 and all i want is MS to offer a working operating system for this machine as a large 4gig iso or something.  I cant spend my life 10 hacking patching reseting wiping goto 10 :¬)
    Lets see
    P.S. im now at factorywipe+powershell and by battery reports 41,902 - almost a cood number for 13 cycles brand new SP2 :¬) - lii add more info as i find it
