2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-15T12:51:32+00:00
    I get full battery-drain overnight now (battery only charges to 40,500 now (MS thanks for the damage)
    yes i did the mystical  "Hold vol + and power button for 15 sec...."
    I also get a lot of reboots now when its idle
    "your pc ran into a problem and....." messages are frequent
    Is there a microsoft website where microsoft reads posts and helps people?
    I will do factory reset AGAIN and do the October driver hack (Powershell script thing)
    to get me back to 1 week battery life (lets hope the recent firmware has not blocked this)
    after this i have no where to go and nothing to do
    I really think I should just "jump up and down on it till i get blisters" TBH :¬(
    Ideally MS we need a proper 5gig download image (option) of a WORKING operating system - Pretty please with sugar on top.
    Mac
    2013-12-15T14:27:13+00:00
    I disabled Surface Cover Telemetry driver in Device Manager, performed a 15sec power+volume up button reset and it seems the random wake and battery meter are fixed respectively... for the time being.
    Does anyone know what Cover Telemetry do?
