2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-10T22:20:29+00:00
    The same thing has happened for me... Windows update says the firmware update failed with error 80070490.  I am not offered to retry the update.
    2013-12-10T22:39:21+00:00
    I pretty much have the same problem, the update is listed as "Failed" in the Windows Update's history. However, the versions of the drivers to seem to be the same as the ones posted in the sticky thread in this sub-forum.
    From what I can tell, everything works or at least, I don't notice any difference. Though, this issue raises concerns, perhaps something did really fail.
    Oh, and what I noticed, while the firmware was being installed, the device restarted a few times. I am not sure if this is expected or not, since I have never installed anything similar (titled "firmware") on another device before.
