2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-15T09:11:20+00:00
    Same issue here
    After a fresh Install of win8.1 (reset from métro settings), i've deployed octobre drivers pack with a script using powershell.
    Run Windows Update
    --->Firmware drivers version are ok, numbers match with the december release
    --->Marvell, Realteck, Cover,Wifi and more are still in October driver pack version, and installing manually won't update .
    Also a strange point:
    -After Installing the update , on the first boot, wifi drivers crash, forced to reboot to get the drivers ok.
    I did 24 reset and update on three different sp2.
    Each time same issue
    We need the December driver pack for a manual install
    2013-12-15T11:52:06+00:00
    I followed the steps posted in this forum and haven't experience any other issues since, basically I performed a system files cleanup after stopping the update service, then rebooted and installed the firmware update. After that I did a hardware reset to fix the battery level problem and so far everything is working fine, its been three days now without problems. Fingers crossed!
