2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-15T07:41:36+00:00
    After 7th reset with numerous combinations, my unit still keep auto-waking, blazing hot cooking in the bag. I don't think it's you... (and this is just my point of view) I think that Microsoft's final update has caused hardware damage to the SP2 machines, hence they have not gotten back to the users.
    2013-12-15T08:29:08+00:00
    Hi
    In response to the above post I have check my unit a couple of times today and found it has waken from Shutdown ...I have selected "Shut Down" and watch everything turn off...only to see if login to the network from another computer I am working on.
    Having come back from an evening out, I find the unit ON and extremely hot... still charging! Surely MS if I select "Shutdown"...is this just the very basic of instructions for the surface to preform? So now I will not leave the unit unattended when I am trying to keep a charge in the battery.
    Does anyone know the ramifications of a battery completely dead...?
    will it recharge?
    Sure hope the Redmond bunch are sleeping well!
