2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-15T04:09:18+00:00
    Things were working OK for me despite a failed update.  Then turned it on today to see BT was not working.  Futzed around with it, gave up.
    Used a restore image b4 the update.  Then, ran update again.  This time things seemed to work.  we'll see how it goes.
    Hey MS, you want us to buy your products instead of an iPad?  Fix this.
    2013-12-15T07:04:41+00:00
    So I can successfully install the firmware update but it fails to update several drivers, even manually installing the drivers won’t update them unless I remove the driver package from the driver store with pnputil.exe, reinstall the October driver pack version and then rerun windows update, though I haven’t quite gotten the process down.
    What I have tried so far
    Using system Admin guy’s version of recovery using the October firmware and deploying it with DISM.
    Deployed drivers on a fresh windows 8 install.
    Clean install of windows 8 and injecting drivers with pnputil.exe
    Clean install and manually updating with device manger
    Default recovery, inject drivers with PNPutil.exe
     I'm on my third surface pro, I really sont want to exchange another one, I think bestbuy cuts you off at some point.
    For now I'm going with the system admin guys version of deployed drivers on the default recovery, at least that worked for the most part, I'll have to hide the firmware update for now, I think I have about 10 hrs into this and am surprised I haven’t gotten things right yet.
